I just got a new Beryl device, been playing with it for couple of days, I am trying to set it up so that I can connect to an OpenVPN server at home, when I am away, I have done this with OpenWRT in the past from other manufacturer (Netgear, Linksys), but this one is being difficult.
I have 2 different OpenVPN Servers, they are configured different, I am able to use them, just not from the Beryl router, I have tested by connecting locally to one of those OpenVPN Server, and the connection remains unstable.
Tested both as a wireless bridge, or completely hardwired, I tested with both DNS Rebinding Attack Protection enabled and disabled, tested Firmwares 3.203, 3.211 and 3.215 beta1, I cleared the config with every firmware change, the router works fine if its not connected to OpenVPN, IPV6 is off.
Fri Jun 3 21:25:08 2022 daemon.notice openvpn[3805]: net_route_v4_add: remote_vpn_server/32 via 192.168.150.1 dev [NULL] table 0 metric -1
Fri Jun 3 21:25:08 2022 daemon.notice openvpn[3805]: net_route_v4_add: 0.0.0.0/1 via 10.8.175.5 dev [NULL] table 0 metric -1
Fri Jun 3 21:25:08 2022 daemon.notice openvpn[3805]: net_route_v4_add: 128.0.0.0/1 via 10.8.175.5 dev [NULL] table 0 metric -1
Fri Jun 3 21:25:08 2022 daemon.notice openvpn[3805]: net_route_v4_add: 192.168.175.0/24 via 10.8.175.5 dev [NULL] table 0 metric -1
Fri Jun 3 21:25:08 2022 daemon.notice openvpn[3805]: net_route_v4_add: 10.8.175.1/32 via 10.8.175.5 dev [NULL] table 0 metric -1
Fri Jun 3 21:25:09 2022 user.info mwan3rtmon[2810]: Detect rtchange event.
Fri Jun 3 21:25:09 2022 user.notice firewall: Reloading firewall due to ifup of ovpn (tun0)
Fri Jun 3 21:25:10 2022 user.notice root: check route success
Fri Jun 3 21:25:10 2022 daemon.warn openvpn[3805]: WARNING: this configuration may cache passwords in memory – use the auth-nocache option to prevent this
Fri Jun 3 21:25:10 2022 daemon.notice openvpn[3805]: Initialization Sequence Completed
