I just tested beryl wifi connection compare to my old router.
IPhone to wifi hotspot =
- 110 Mbps via Beryl
- 480 Mbps via old router.
Both using 5G spots
Anything I can adjust ?
Both using 5G spots
Maybe adjust channel?
Thank you Alzhao.
I suspect partially the reason for this issue was that existing router (Eero) sucked all QoS on a switch where both Eero and Beryl were connected to. I not sure if it makes any sense but somehow Eero might of consumed most of bandwidth from other devices.
I reconfigured everything and it helped a bit.
