Beryl tethering problem
My Beryl router is losing the USB tethering connection very frequently. At least every 2-3 days.
Setup:
  • Beryl, FW 4.3.19
  • iPhone 11, iOS 18.2.1
  • the iPhone is not doing anything else than providing the tethering hotspot
  • I changed the USB-Lightning cable several times with no effect
Tethering works perfectly fine, fast, no interruptions. But after 2-3 days all of a sudden the connection drops. No reboot is required to re-connect, just unplugging and re-plugging the USB-lightning cable does the trick.
Any suggestion how to fix this? Very often I‘m remote when the tethering drops. Then I can’t access my network remotely anymore before fixing the broken tethering connection on-site. That’s damn annoying.
I would try to reset the iPhones network configuration, this can help from time to time.
See 7.:
It would be good to know what is written in the logs when the tethering drops.
I can’t count how often I resetted both devices already without any effect. USB tethering is very unstable.
How do I get the log to send it to you?
You might need to share the device as well, please follow Technical support via GoodCloud - GL.iNet Router Docs 4 and share the logs with @bruce
