I have the typical beryl to beryl vpn tunnel on wireguard.
It’s been working good aside from a few hiccups until today.
Both on 3.2xxx
I connected my client router to a new wifi and it won’t work.
Only yellow light on vpn status.
Tried other WiFi’s, nothing.
Tried LTE hotspot, nothing.
Tried hotpot with wire guard app and client config, then connected with other phone and that worked. So it’s not the config at least.
Here are some logs from when I try to make a vpn connection.
I AM DESPERATE FOR HELP
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: * Zone 'guestzone'
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: * Zone 'wireguard'
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: * Populating IPv4 nat table
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: Warning: fw3_ipt_rule_append(): Can't find target 'prerouting_wireguard_rule'
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: Warning: fw3_ipt_rule_append(): Can't find target 'postrouting_wireguard_rule'
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: * Zone 'lan'
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: * Zone 'wan'
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: * Populating IPv4 mangle table
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: * Populating IPv4 raw table
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: - Using automatic conntrack helper attachment
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: * Clearing IPv6 filter table
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: * Clearing IPv6 nat table
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: * Clearing IPv6 mangle table
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: * Populating IPv6 filter table
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: Warning: fw3_ipt_rule_append(): Can't find target 'input_wireguard_rule'
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: Warning: fw3_ipt_rule_append(): Can't find target 'output_wireguard_rule'
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: Warning: fw3_ipt_rule_append(): Can't find target 'forwarding_wireguard_rule'
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: * Rule 'Allow-DHCPv6'
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: * Rule 'Allow-MLD'
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: * Rule 'Allow-ICMPv6-Input'
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: * Rule 'Allow-ICMPv6-Forward'
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: * Rule 'Allow-IPSec-ESP'
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: * Rule 'Allow-ISAKMP'
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: * Rule 'guestzone_DHCP'
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: * Rule 'guestzone_DNS'
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: * Rule #11
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: * Rule #12
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: * Forward 'wireguard' -> 'wan'
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: * Forward 'wireguard' -> 'lan'
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: * Forward 'lan' -> 'wireguard'
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: * Forward 'guestzone' -> 'wireguard'
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: * Forward 'wireguard' -> 'guestzone'
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: * Populating IPv6 nat table
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: Warning: fw3_ipt_rule_append(): Can't find target 'prerouting_lan_rule'
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: Warning: fw3_ipt_rule_append(): Can't find target 'postrouting_lan_rule'
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: Warning: fw3_ipt_rule_append(): Can't find target 'prerouting_wan_rule'
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: Warning: fw3_ipt_rule_append(): Can't find target 'postrouting_wan_rule'
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: Warning: fw3_ipt_rule_append(): Can't find target 'prerouting_guestzone_rule'
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: Warning: fw3_ipt_rule_append(): Can't find target 'postrouting_guestzone_rule'
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: Warning: fw3_ipt_rule_append(): Can't find target 'prerouting_rule'
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: Warning: fw3_ipt_rule_append(): Can't find target 'postrouting_rule'
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: * Populating IPv6 mangle table
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: * Set tcp_ecn to off
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: * Set tcp_syncookies to on
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: * Set tcp_window_scaling to on
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: * Running script '/etc/firewall.user'
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: uci: Entry not found
Thu Feb 29 20:52:57 2024 daemon.err gl_monitor[6125]: iptables: No chain/target/match by that name.
Thu Feb 29 20:52:58 2024 daemon.err gl_monitor[6125]: * Running script '/usr/bin/glfw.sh'
Thu Feb 29 20:52:58 2024 daemon.err gl_monitor[6125]: * Running script '/var/etc/gls2s.include'
Thu Feb 29 20:52:58 2024 daemon.err gl_monitor[6125]: ! Skipping due to path error: No such file or directory
Thu Feb 29 20:52:58 2024 daemon.err gl_monitor[6125]: * Running script '/usr/sbin/glqos.sh'
Thu Feb 29 20:52:59 2024 daemon.err gl_monitor[6125]: /sbin/uci: Invalid argument
Thu Feb 29 20:53:00 2024 user.info mwan3rtmon[2743]: Detect rtchange event.
Thu Feb 29 20:53:01 2024 daemon.err gl_monitor[6125]: uci: Entry not found
Thu Feb 29 20:53:01 2024 user.notice wiregaurd: client start completed, del glwg.lock
Thu Feb 29 20:53:03 2024 kern.warn kernel: [ 503.253147] ACT - SendBSS2040CoexistMgmtAction(BSSCoexist2040=0x6)
Thu Feb 29 20:53:03 2024 kern.warn kernel: [ 503.259516] ACT - SendBSS2040CoexistMgmtAction(BSSCoexist2040=0x6)
Thu Feb 29 20:53:03 2024 kern.warn kernel: [ 503.265866] ACT - SendBSS2040CoexistMgmtAction(BSSCoexist2040=0x6)
Thu Feb 29 20:53:03 2024 kern.warn kernel: [ 503.272226] ACT - SendBSS2040CoexistMgmtAction(BSSCoexist2040=0x6)
Thu Feb 29 20:53:03 2024 kern.warn kernel: [ 503.278516] ACT - SendBSS2040CoexistMgmtAction(BSSCoexist2040=0x6)
Thu Feb 29 20:53:03 2024 kern.warn kernel: [ 503.284838] ACT - SendBSS2040CoexistMgmtAction(BSSCoexist2040=0x6)
Thu Feb 29 20:53:03 2024 kern.warn kernel: [ 503.291060] ACT - SendBSS2040CoexistMgmtAction(BSSCoexist2040=0x6)
Thu Feb 29 20:53:03 2024 kern.warn kernel: [ 503.297386] ACT - SendBSS2040CoexistMgmtAction(BSSCoexist2040=0x6)
