Beryl WPA3 Issue with iPhone
I have a MT1300, firmware 3.215, wireless repeating a hotel WiFi.
When I had WPA2+WPA3 enabled, or if I had WPA3 only enabled, I am unable to connect with iPhone. When I try to connect, the phone tries to connect but never succeeds. It just spins until it gives up/
When using an Intel MacBook, it seems to connect just fine.
In the luci system logs, I see the following errors.
kern.warn kernel: [ 6402.194485] MlmeADDBAAction: PMF connection, Ignore AddBaReq Send DUE TO NOT IN PORTSECURED
Doing a wireshark capture, I see that EAPOL only has message 1 of 4, 2 of 4, 3 of 4. It just continuously sends 3 of 4 message.
Switching over to WPA2-PSK seems to allow the phones to connect.
Googling that error message brings up
Perhaps it is related to some management frame issue?
You are right. I filed a bug internally.
Firmware 4.x does not have this problem.
This problem happens on IOS16 and later.
I see a beta is out for Beryl. Do you have a confirmed stable release date for Beryl that will resolve?
Sorry I don’t have.
But Beryl 4.x firmware has gone through several beta now. So usable.
