Hello everyone,
As I will be traveling a lot more in the next months I am currently looking for a way to securely access my home network even when I will be away. The GL.Inet products seems to be the best fit to do that but before buying them I’d like to be sure that my analysis is correct.
My current home set-up is quite simple. My ISP provided router is connected to the internet. It locally acts as a DHCP server and all my devices are connected to it either using wifi or ethernet.
Imgur: The magic of the Internet (sorry for external link but as a new user I can only embed one image)
In order to acheive my target I was thinking of adding a GL-B1300 to my home set-up:
- It will be connected to my ISP provided Router on the WAN port
- It will act as the DHCP server for my LAN
- It will provide the Home Wifi
- It will act as VPN Server
When I will be traveling I will take with me a GL-MT1300 Beryl :
- It will be connected in repeater mode to the hotel wifi network
- It will act as a VPN Client, connected to my at home VPN Server
- It will act as a local LAN router to connect my phone/laptop (either via wifi ou ethernet)
The two main goals I would like to achieve with this set-up, when using my laptop remotely while traveling are :
- To have the same external IP adress as if I was using it from my home
- To be able to access some files that are stored in my home network
As I am not a netowrking expert can someone please tell me if :
- All of this makes sense ? Can my goals by achieved with this set-up ?
- Is this way of doing secured ?
- The GL-B1300 and GL-MT1300 are the best fit ? Are they powerful enough ?
- Their are resources/tutorials on how to set-up this kind of network ?
Any insight would be greatly appreciated.
Thanks a lot for your time reading this long post.
