Best external USB hard drive for MiFi?
Just ordered a MiFi, and it looks like the external drive requirements are max 1TB, and powered, but thats a really unusual drive (at 1TB they are usually mobile, and USB powered). What can I use?
Or, will a 1TB Samsung T5 (SSD) work? (thinking it doesn’t draw much power, similar to USB stick?)
A powered USB hub can help if you run into power problems.
According to Miscellaneous Aspects and Concluding Remarks - Samsung Portable SSD T5 Review: 64-Layer V-NAND Debuts in Retail, the T5 will draw up to ~3.5 W, which is in excess of the 500 mA * 5 V = 2.5 W that USB 2 can supply.
