can I ask you which is your favorite LTE modem for the Slate? Is it possible to see the LTE signal level from the Slate Web GUI?
Thanks
Andrea
Thanks
Andrea
You cannot see the LTE signal from Slate. The signal from modem is actually obtained using AT command. It really depends on the modem if they can return the signal via AT command.
We only get signal for Quectel modems, which we use on our 4G devices.
Thanks guys for the clarifications and suggestions!
