How do you install ProtonVPN/nordVPN on your MT300N-V2. I went to applications > plug-ins and i didnt see it. Is there a special want to install it?
Please read the docs OpenVPN Client - GL.iNet Docs
Surfbouncer works fine and I remember seeing that they sell the AR300M pre-configured for viewing Netflix. I’ve used the AR300M and most recently the MT300M for travel use without issues.
Very true…
Conexa makes for a good VPN end-point, and Brume will be even a better end-point.
The GL-Inet firmware makes this almost point and click for most folks.
Should note - hosting a VPN in the cloud is getting easier these days - set up a Linode/Digital Ocean VPS instance, and running the endpoint there…
Very helpful thread, But I can’t recommend you any VPN because no one is best. Every VPN offers its best features; some are good for streaming and are good for security, So I recommend reading unbiased reviews on famous websites like Reviewsed.com, So it will help you in taking the right decision.
