If I have a lot of devices to configure, I’d rather not go to to the web page for the device, I’d rather do everything from a script instead.
I know I can set timezone and password from CLI. I don’t know about language, I don’t know if this is just the language for the web UI, or if it is a system setting.
Assuming I can set all three of these, is there anywhere else I need to tell the device to never show the initial setup menu again?
This is what’s going to keep me buying GL.iNet products … the high quality and technical depth of the users and forums.
“Linksys Technical Support: Please factory-reset your router and if the problem persists, contact the retailer you purchased your product from for a full refund.”
