Beta Testing section is currently open
it seems the Beta Testing section has been open for a while. Is this section going back for a restricted visibility state for new beta testing?
Is there any issue if we publish information/pics, like bugs or speed/energy consumption, in this section of the forum while it is open (as beta testers)?
This is about new devices like Beryl AX (GL-MT3000) and Brume 2 (GL-MT2500).
Yea why is beta testing forum open to public
Btw there’s no beta testing for brume 2
Yes Beta testing is public.
But if you are new product tester, you should have a private category.
@defibos are you tester of MT3000?
I’m testing GL-MT2500 but don’t see a private category.
Yes, Beryl AX (GL-MT3000).
Where is the private private section?
For Brume 2 testing just post in this category. Thanks!
Ok, it seems a new section for Beryl AX (GL-MT3000) was created but I was not included. Fixed now.
Thanks.
