Big bug on GL-MT3600BE (Beryl 7)
I bought this router and chose the best model to get reliability, but I keep experiencing continuous reboots and freezes. When it freezes I absolutely have to restart it, otherwise it stays stuck and completely unresponsive.
This is an example of the bug scenario.
Configured as a repeater and connected via WiFi to my main router, I initially set everything up using my PC over WiFi and it worked at first. As soon as I connected a PC to the LAN port of the GL.iNet router (so 1 PC on WiFi plus 1 PC on LAN), the GL.iNet freezes and loses the WiFi connection to the main router. After a while it reconnects to the main router via WiFi, but at that moment it drops the LAN connection of the GL.iNet and disconnects the PC on the LAN. Shortly after it starts again, the LAN connection comes back and the WiFi connection drops.
I reset the GL.iNet router and configured everything through LAN. Now if I keep only the PC connected via LAN it works perfectly. As soon as I connect a device to the GL.iNet WiFi, the router freezes and even the LED turns off. The only way to recover it is to unplug the power and plug it back in.
Is this problem reproducible in your environment?
Does the repeater disconnection problem occur if any two or more devices are connected to the router's LAN and WiFi at the same time?
I'm unable to reproduce the problem in my local test. Is it still possible to access the router's GUI after the problem occurred?
Does the router print any crash logs?
Is your router running firmware version 4.8.5? Could you please export the router logs containing the abnormal process and send them to us for inspection?
If your system logs contain sensitive information, please contact us at support@gl-inet.com and include a link to this post.
