Block access to my Gateway
I want to block the access to my default gateway (192.168.8.1) so any client connected to the router and trying to access the admin panel can be blocked to this website.
I still want to be able to access the admin panel of this router but only through goodcloud.
How is this possible?
I tried creating a rule on Luci by following theses stesps:
In the GLiNet Panel, went to MORE SETTINGS :arrow_right: Advanced
From there opened Luci.
In Luci I went to Network :arrow_right: Firewall :arrow_right: Custom Rules
Here I put:
iptables -I FORWARD -i br-lan -d 192.168.1.0/24 -j DROP
iptables -I FORWARD -i br-lan -d 192.168.1.1 -j ACCEPT
Then click on Restart Firewall.
But nothing happened, I am still able to access the web panel (192.168.8.1) when I am connected to this router.
To restrict unauthorized access to the router while maintaining network functionality, please follow these steps:
  1. Modify Firewall Defaults: Navigate to LuCI > Network > Firewall. Under the General Settings tab, find the LAN zone and change the Input default setting from Accept to Drop or Reject.
  2. Add Traffic Rules: To ensure your connected devices can still function, go to the Traffic Rules tab and add two rules to allow essential services:
    (Scroll to the bottom of the page)
  1. Save and apply the configuration, then restart the router for the changes to take effect.
Note: These changes will not affect your ability to manage the device via GoodCloud. However, if a configuration error occurs and you lose local access, you will need to perform a factory reset to restore the default settings.
@will.qiu Thank yo for the steps provided.
Could you please describe the steps for “Add those traffic rules” as you did on part 1 (Modify Firewall Defaults)? I tried by my own but it does not look like the image you put and I want to make sure the configuration is correct.
Thanks again.
Sorry for the delayed reply.
I have added more specific operating steps to the original post.
Since you did not specify the device model or firmware version, I use the Flint 2 v4.8.3 as an example.
The LuCI interface on other device models may differ, but they should all include similar configuration fields.
You also can refer to the built-in DNS/DHCP rules created for Guest to configure the corresponding settings for LAN.
@will.qiu Thank you so, so, so much. It worked perfect and I truly apreciate the help. :slight_smile:
