Block DHCP from external (wan)
How to block external DHCP?
It looks like it can be vulnerable:
Also will Gl.iNet patch it out?
If you block DHCP on WAN you will likely no longer be able to use the travel routers for travel. There is a LONG thread on this one if you want to search for it. @admon - should this thread be closed?
Yup, will close this thread.
This topic was discussed more than enough: Are Glinet mobile router protected against CVE-2024-3661 (tunnelvision)?
