Block guest to lan
I have setup the AX1800 router with OpenVPN Client.
The Firmware is on the latest 4.6.8
  • VPN policy base on VLAN with Private VLAN Enable VPN ON
  • Guest VLAN Enable VPN OFF.
Also AP isolation is ON.
  • Network > Guess Network > AP isolation is ON
There are no other network equipment involved.
With this setup, Guest network 192.168.9.0/24 should not have access to the Private network 192.168.8.0/24 right?
But in my setup, they can ping each other although they should not be able to.
  • 192.168.8.210 can ping 192.168.8.230.
And 2 machines that are connected to the Guest wifi can ping each other when AP isolation is ON.
  • 192.168.9.210 can ping 192.168.9.211
How would I block the Guest network from being able to talk to the Private network and vice versa? Do I need to do this using iptables?
  • Guest <-block-> Private wired LAN and Private wifi
  • Private LAN and Private wifi SSID <-block-> Guest
And also block computers connected to the Guest wifi from being able to talk to each other
  • Guest <-block-> Guest
With guest isolation only the wireless segment should be isolated (it uses hostapds isolation feature), however creating a fw rule like this won't work, you need firewall filtering inside the bridge which can be done with ebtables, or ebtables-nft (i think this one is not recommend due flint 1 still using iptables).
ebtables -A FORWARD --logical-in yournetworkinterface -j DROP
Then make the rule apply at each restart.
However since Flint 1 uses the openwifi/wlanap sdk it is possible these features for wireless isolation are very limited and may not work, i think someone from GL-iNet knows this better.
