How to Block remote access the web Admin Panel of GL.iNet router GL-AX1800 Flint (4.2.3) , regardless of what I do, I am unable to block web admin panel access from internet ( http://mypublicip )
Did you enable Open Ports on Router and/or set up Port Forwards? Check that on Admin Panel → NETWORK → Firewall.
yeah port forward was enable at some point, but it is disabled now … it should not go to web admin page
You can try deleting the record completely. Maybe there is a glitch.
the record is not even pointing to router…
record is deleted…
web admin page is still accessible from outside…
i tried disabling dynamic dns…
I also tried with goodcloud off still no luck
Log into LuCI and go to Network → Firewall:
- Confirm that the Zones section in the Firewall - Zones Settings tab do not allow access through WAN:
- Confirm that the Firewall - Port Forwards tab does not have any port forwarding rules.
Disabling DDNS does not remove the previous update already done.
I do not use GoodCloud, so do not know if that has an effect.
