The VPN needs to be reset, it is not connecting. Sometimes this happens, and I need to change VPN server/location.
I am away from my router, so I cannot connect remote.
I can remote into my phone, but I can’t configure the router from my phone because if I switch phone to wifi and connect to router, I lose the remote because it will no longer be connected to internet.
The solution would be if I used the glinet app and had the ability to connect to the router and configure via BLUETOOTH.
