Are you sure? I think we should focus on the optimization of USB 3.0! The network speed of my plug-in EP06 4G module is not ideal. 2ca doesn’t seem to be suitable for my country. There is no problem with the driver, but the delay is very high. The mobile device here supports 4G on a single frequency+
Use the correct language. As you are in China, our Chinese colleague can easily help you if you post in Chinese. English is fine but those speaking English are not in China.
@alzhao That’s what it seemed to me. On github I saw that gl_bletool supports only Silconlabs EFR32 BLE. While the MT1300 beryl has TLSR8251.
@alzhao Could you please guide me on how to use Bluetooth on MT1300? I saw that the thermometer from xiaomi uses the same chipset but it did not help me. I tried to use the BlueZ and serial but it didn’t work for me.
We will release our new app quite soon. So you will have the app, scan and you will find MT1300. You can configure SSID, key etc via BLE. This is how it is used.
I understand. Will this application be opensource? If so, on the basis of this application I could create my own which will be used for their own purposes.
