Bricked MiFI
all of the sudden my mifi v2.5.5 doess not boot.
it only shows the power led solid green when i connect usb power.
i have tried holding the reset button but there's no flashing light just the solid power led.
NB: i didnt perform any update or firmware changes that might have resulted to this brick
any help is appreciated.
May I know the model number?
And please try this method for the firmware recovery:
Debrick via Uboot - GL.iNet Router Docs 4
my model is GL-MiFi
when i hold the reset button nothing happens thus it does not enter into uboot.
its only the power light that comes on.
no other led turns on aside the power led.
As so, there maybe some hardware issue.
This model is a bit old and end of life. I think it shall be out of warranty as well.
Would it convenient for you reach our cs teams (cs@gl-inet.com) to get a discount for a new model?
Such as XE300: GL-XE300 / Puli - GL.iNet
am currently in africa.
will hold on with your options
