Bricked Slate AX GL-AXT1800 after U-Boot Firmware Update - No LEDs, No Boot
I attempted to update the firmware of Slate AX GL-AXT1800 via U-Boot, and I fear I may have selected the wrong firmware file during the process. Now, the router seems to be completely bricked.
Here are the symptoms:
  • No LED: When I plug in the router, absolutely no LED illuminate – not even a flicker.
  • No Boot: The router does not seem to boot at all.
  • Cannot access U-Boot: I've tried the usual methods (holding the reset button during power-on) to get back into U-Boot mode, but it's unresponsive.
I'm concerned I've completely bricked the device. Has anyone encountered a similar situation with the GL-AXT1800 or other GL.iNet routers?
Any advice, suggestions, or shared experiences would be greatly appreciated. I'm really hoping to revive my router
Thanks in advance for your help
  1. Please try to change the power/data cable.
  2. Try again by pressing and holding the reset button, then plugging in the power, observing the LED status, and whether you can enter the u-boot page.
  3. If the problem persists, please contact [email protected].
