@zana, the uboot need to check mac addresses. Could pls send us an email, with a photo of your device’s bottom label, so that we send you another little file to load in your device.
email: service@gl-inet.com
@zana, pls give me your email. I will send it to you. As it contains unique data for this device, I don’t want to attach here.
Hi all! Please help!
I have bricked AR150.
I flashig u-boot, art_default, art_calibration and openwrt-ar150-2.13.bin
I stop on this step (config.bin?!):
@revector, I send the config.bin to you via email.
Many thanks! Today, I will try and let you know the result.
All works! Only NOT work WiFi! I dont found this interface over air. May be brocken interface WiFi?
one thing for wifi, is that you changed the art. Please be noted that the art is unique for each router. If you change this to a default art, it may affect the wireless signal. If you don’t have wifi at all, pls check system log and find out the error info. Maybe you need another art.
I dont change the art! I dont know how to change the art. I flash files on this forum. I clear flash rom on the USB programmer first.
