I try change the firmware a own compiled openwrt and not work. For make this y use using u-boot web failsafe. Then try to use web failsafe for recover the firmware and the uboot say me tath command httpd not find. The try to recover the firmware with uboot console with Tftp. I use this commands:
All work fine but after reset the AR-150 not work more. The AR150 don´t print anything in the serial console. How can repair the AR150? How can charge the uboot again?
Best Regard
P.D I changed the firmware a lot of time my WR703N via console with tftp. I thin than my problem is the direcctions of memmroy are wrong
I am sorry to hear you news。
Your router is broken。
right commands:
uboot> tftp 0x81000000 openwrt-ar150-2.12.bin
uboot> erase 0x9f050000 +0x7c0000
uboot> cp.b 0x81000000 0x9f050000 0x7c0000
uboot> reset
we have made automatic commands in uboot,the commands are:
run lu ----> to replace uboot
run lf ----> to replace firmware
Please you can give me de HEX to program the flash and information for make that. I de-soldeler the flash and try to program because i want to recover this AR-150.
I have some programers in my home but i don’t know if work with this flash. This afternoon I research for that. If don´t work i buy one. What is the model of the flash that haver the AR150.
One recover the AR150 y write some information for help the next people happend this.
I desolder the menory , programed and solder again. I concect de ar150 to serial port and the ubbot load well.
Then congifure the MAC with this command: setmac XX:XX:XX:XX:XX:XX , active the httpd, open browser in this direction 192.168.1.1 and load the firmware i try the 2.12 and 2.13 versions. When restart the ubout say me this:
“Cannot find art, please flash the default art first”
