Browser client doesn't forward system keyboard shortcuts to remote machine in full screen
When connecting to a remote machine via the browser-based client and pressing full screen, system-level keyboard shortcuts (like Alt+Tab, Win+R, and the Windows Key) are captured by the local machine instead of being sent to the remote machine.
Steps to Reproduce:
  1. Connect to a remote machine using the browser client (not the GLKVM Cloud app)
  2. Press Alt+Tab, Win+R, or the Windows Key
  3. Observe that these shortcuts are handled by the local machine
Expected Behavior: Keyboard shortcuts should be forwarded to the remote machine, similar to how the GLKVM Cloud app behaves.
Actual Behavior: Shortcuts are intercepted by the local browser/OS and never reach the remote machine.
Workaround: Currently works as expected when using the GLKVM Cloud app instead of the browser client to connect directly by local network.
Solution:
  1. Please add option to the GLKVM app to connect remotely via LAN
  2. Pressing full screen button should force shortcuts to pass to remote machine
Thank you for recommandation, I have collected your advice and submit to our R&D team.
Additional solution: you can try the toolbox-shotcuts.
Which browser are you using? Is it Firefox? Firefox blocks the system keyboard.
i tried on Firefox, Brave and Edge
ALT+TAB Should be work on Edge or Chrome
