decided to purchase Brume 2 and Beryl AX. However, I am currently experiencing a problem with Brume 2, while Beryl AX is easy to configure.
I want to achieve the following:
- Run a WireGuard server on Brume 2.
- Access the Brume login page ( 192.168.8.1) while using my current WiFi router.
Here is my current setup:
- XFINITY modem in bridge mode, with an Ethernet cable going to my Asus router, which provides WiFi.
Here is what I have done so far:
I connected an Ethernet cable from the WAN port of Brume to my Asus LAN port.
The Asus router assigned an IP address to Brume, which I set to be static.
I was able to log in to the Brume page and enable Bridge mode, but then I lost the VPN section.
I switched back to network mode and changed it to Router, which brought back the VPN option.
On the main router, I port forwarded port 51820 (UDP and TCP) to the Brume IP address.
I connected back to the Brume and enabled DDNS.
I changed the WireGuard server IP from 10.0.0.1 to 10.20.0.X/24 because XFINITY uses 10.0.0.1 for their home router gateway.
Then, I created a WireGuard client config, making sure to reference the DDNS URL instead of my public IP address.
I don’t need adblock on Brume because my Asus router already has the adguard server running on custom Merlin firmware. All I need is a WireGuard server.
My question is why does the WireGuard server only work in router mode and not in bridge mode? Is there a way to run the WireGuard server in bridge mode, as that is my preference?
Please keep in mind that I am still new to networking, so any help would be greatly appreciated!
