I have a Brume 2 I am having constant issue with power light blinking ISP is ATT modem in IP pass through mode connected to a Opnsense device I have the brume behind of the device. When I connect a cable to LAN 1 port the device seems to be stable once I disconnect the cable from LAN port the power light starts to blink. I have reset the device try Firmware 4.5.0, 4.5,4.6.2
Is the WAN port of Brume2 connected to OpenSense device, right?
What lower device is connected the Brume2 via the Brume2 LAN
yes the wan port is connected to opnsense router My laptop is connected to the LAN port on the Brume laptop running Zorin OS
Let me further confirm,
- Would the power indicator light turn blue and blink if the LAN port is disconnected while the WAN port remains connected?
- Any notice in the GL GUI -> INTERNET Interface? like key words 'no internet'
- Could you please export the syslog (GL GUI -> SYSTEM -> Log) and PM me.
I was just helping someone with this same issue. It was a bad Ethernet cable. This also happened to be the culprit for another person with this issue on Reddit.
Thanks for your help. ![]()
After Uboot upgrade my power light is blinking I have try a brand new ethernet cable that I received with my with slate 7 same issue will go solid then start blinking again. I have try using the USB -C cable that came with the slate 7 same issue
Please email contact our support team support@gl-inet.com.
