I have no Ethernet at the moment but need to setup the Brume 2 to my Tim Hub (Italian ISP Provider).
However I do own a Beryl AX which I use for travel. I was wondering:
If I connect the Beryl AX as an AP to the Tim Hub and the Brume 2 to the Beryl X, would that allow me to connect for a setup? If not, is there another way?
Are there any instructions on how to change the Network IP on the Tim Hub ( Modem TIM Hub+ | TIM ) so I can access the Brume 2?
Just trying to resolve this over the weekend as Amazon delivers only on Monday for an ethernet connector.
This will create some really terrible DHCP issues, but it should make you able to reach the Brume.
Maybe you need to set your own device (like your laptop) to a static IP from Brumes default network.
All in all you need to try a bit around, but it should work.
You could try to use AP mode on your Beryl and plug it into LAN of Brume without Internet. Should be good enough for first setup as well.
