I hope I’m not violating any posting rules but I have a simple question. Do I install the Brume VPN wireguard server 1st in the network right? And then I need to make the nighthawk WiFi router into a gateway since the BRUME 2 GL-MT2500 is the VPN Access Point? Thank you for your support.
Depends on what you are trying to do. If you want to route everything through VPN (or at least using VPN policies) then yes, you are right.
Mostly it looks like this:
I ended up setting it behind the router & port forwarding. Do I need use DDNS domain ON? Every-time I make a client profile it defaults to NO so I’m guessing leave it off?
Sorry Admon, I didn’t clarify what I’m trying to do. I wanna setup a Gl-iNet Brume 2 as a home vpn server and another Gl-Mt1300 router as client so that when I use the MT1300 oversees it connects to the Brume 2 here in USA to access Netflix etc. I got the https://www.goodcloud.xyz all working and I can see & login to Brume 2 but I don’t know if my dynamic public ip is gonna stay the same or do I need to enable some DNS service. Thanks,
Yup; you should enable the DDNS service then.
