After Uboot upgrade my power light is blinking I have try a brand new ethernet cable that I received with my with slate 7 same issue will go solid then start blinking again. I have try using the USB -C cable that came with the slate 7 same issue. I could share my logs
Please also upgrade the router firmware v4.7.4:
https://dl.gl-inet.com/router/mt2500/stable
Please share issue syslog with us, before exporting the log, first re-plug the WAN port network cable.
Below is the Sys log
logread.tar (122 KB)
I have connected my Beryl (GL-MT1300) to the same Ethernet cable and using the brume 2 usb c power cord setup a new wireguard server and I have no blinking light
The LED blinking blue generally indicates the Internet access status is abnormal.
But I did not find that the Brume 2 WAN was disconnected in the syslog.
The syslog shows that after the router system is started, the WAN port starts working and normal, and the WG server starts normally:
May I know if Brume 2 cannot connect to the Internet when it upgraded the uboot and v4.7.4 firmware?
If Brume 2 blue light, please SSH to the Brume 2 to check:
ifconfig
ip route
ping www.google.com
ping 8.8.8.8
