Hello!
I have finally received my awaited BRUME 2, however the first few hours have not been the best!
I have FTTP (Fibre ONT modem) that currently connects to my existing Amplifi HD Mesh router. This has PPPOE already setup / working fine.
Now I would like to connect BRUME 2 as my main router [ONT MODEM → BRUME 2 → Amplifi HD Router (Bridge Mode)] however connecting to the PPPOE account has been hard work!
At this point i have the existing HD router turned off, and i have only connected the BRUME 2 to the ONT Modem.
- I have restarted the ONT multiple times, including Brume 2
- I have cloned the existing HD Router MAC and put onto the WAN ETH0 port for the BRUME 2 (NO difference in connection logs)
- lost all patience.
- The PPPOE account is exactly the same as the existing setup, if i reconnect my OLD router back into the ONT, internet works again (horray).
Logs outputed from BRUME 2 when attempting to setup PPPOE:
Fri Aug 11 08:57:10 2023 daemon.info pppd[7683]: Plugin rp-pppoe.so loaded.
Fri Aug 11 08:57:10 2023 daemon.info pppd[7683]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.8
Fri Aug 11 08:57:10 2023 daemon.notice pppd[7683]: pppd 2.4.8 started by root, uid 0
Fri Aug 11 08:57:10 2023 daemon.info pppd[7683]: PPP session is 635
Fri Aug 11 08:57:10 2023 daemon.warn pppd[7683]: Connected to d8:18:d3:9e:d6:ab via interface eth0
Fri Aug 11 08:57:10 2023 kern.info kernel: [ 48.267617] pppoe-wan: renamed from ppp0
Fri Aug 11 08:57:10 2023 daemon.info pppd[7683]: Renamed interface ppp0 to pppoe-wan
Fri Aug 11 08:57:10 2023 daemon.info pppd[7683]: Using interface pppoe-wan
Fri Aug 11 08:57:10 2023 daemon.notice pppd[7683]: Connect: pppoe-wan ↔ eth0
Fri Aug 11 08:57:11 2023 daemon.info pppd[7683]: CHAP authentication failed: Realm not found in wholesaler
Fri Aug 11 08:57:11 2023 daemon.err pppd[7683]: CHAP authentication failed
Fri Aug 11 08:57:12 2023 daemon.info avahi-daemon[3550]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::9683:c4ff:fe33:####.
Fri Aug 11 08:57:12 2023 daemon.info avahi-daemon[3550]: New relevant interface eth0.IPv6 for mDNS.
Fri Aug 11 08:57:12 2023 daemon.info avahi-daemon[3550]: Registering new address record for fe80::9683:c4ff:fe33:#### on eth0..
Fri Aug 11 08:57:17 2023 daemon.notice pppd[7683]: Connection terminated.
Fri Aug 11 08:57:17 2023 daemon.info pppd[7683]: Sent PADT
Fri Aug 11 08:57:18 2023 daemon.notice pppd[7683]: Modem hangup
Fri Aug 11 08:57:18 2023 daemon.info pppd[7683]: Exit.
Fri Aug 11 08:57:18 2023 daemon.notice netifd: Interface ‘wan’ is now down
Fri Aug 11 08:57:18 2023 kern.info kernel: [ 55.497205] mtk_soc_eth 15100000.ethernet eth0: Link is Down
Fri Aug 11 08:57:18 2023 daemon.info avahi-daemon[3550]: Interface eth0.IPv6 no longer relevant for mDNS.
Fri Aug 11 08:57:18 2023 daemon.info avahi-daemon[3550]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::9683:c4ff:fe33:####.
Fri Aug 11 08:57:18 2023 daemon.info avahi-daemon[3550]: Withdrawing address record for fe80::9683:c4ff:fe33:#### on eth0.
Fri Aug 11 08:57:18 2023 daemon.notice netifd: Interface ‘wan’ is disabled
Fri Aug 11 08:57:18 2023 kern.info kernel: [ 55.509815] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
Fri Aug 11 08:57:18 2023 kern.info kernel: [ 55.518174] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
Fri Aug 11 08:57:18 2023 kern.info kernel: [ 55.526926] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Fri Aug 11 08:57:18 2023 daemon.notice netifd: Interface ‘wan’ is enabled
Fri Aug 11 08:57:18 2023 daemon.notice netifd: Interface ‘wan’ is setting up now
Fri Aug 11 08:57:18 2023 daemon.err insmod: module is already loaded - slhc
Fri Aug 11 08:57:18 2023 daemon.err insmod: module is already loaded - ppp_generic
Fri Aug 11 08:57:18 2023 daemon.err insmod: module is already loaded - pppox
Fri Aug 11 08:57:18 2023 daemon.err insmod: module is already loaded - pppoe
Fri Aug 11 08:57:18 2023 daemon.info pppd[8277]: Plugin rp-pppoe.so loaded.
Fri Aug 11 08:57:18 2023 daemon.info pppd[8277]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.8
Fri Aug 11 08:57:18 2023 daemon.notice pppd[8277]: pppd 2.4.8 started by root, uid 0
Fri Aug 11 08:57:19 2023 daemon.info avahi-daemon[3550]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::9683:c4ff:fe33:####.
Fri Aug 11 08:57:19 2023 daemon.info avahi-daemon[3550]: New relevant interface eth0.IPv6 for mDNS.
Fri Aug 11 08:57:19 2023 daemon.info avahi-daemon[3550]: Registering new address record for fe80::9683:c4ff:fe33:#### on eth0..
Fri Aug 11 08:57:33 2023 daemon.warn pppd[8277]: Timeout waiting for PADO packets
Fri Aug 11 08:57:33 2023 daemon.err pppd[8277]: Unable to complete PPPoE Discovery
Fri Aug 11 08:57:33 2023 daemon.info pppd[8277]: Exit.
The main line pointing out to me is:
However i cannot find much information about it, and to repeat myself the PPPOE Accout and PW is exactly the same as the existing router (That works!).
ie: username@broadband.vodaphone.co.uk
Am i missing anything here?
*DropIn GW in not something i am interested in.
Thanks in advance!!
system info (redacted)
uci show network
network.wan=interface
network.wan.force_link=‘0’
network.wan.ipv6=‘0’
network.wan.password=‘############’
network.wan.disabled=‘0’
network.wan.peerdns=‘1’
network.wan.proto=‘pppoe’
network.wan.device=‘eth0’
network.wan.username=‘username@broadband.vodaphone.co.uk’
network.wan.vlanid=‘0’
uci show system
system.@system[0]=system
system.@system[0].log_size=‘64’
system.@system[0].urandom_seed=‘0’
system.@system[0].hostname=‘GL-MT2500’
system.@system[0].compat_version=‘1.0’
system.@system[0].ttylogin=‘1’
system.@system[0].timezone=‘GMT0BST,M3.5.0/1,M10.5.0’
system.@system[0].zonename=‘Europe/London’
system.@system[0].log_proto=‘udp’
system.@system[0].conloglevel=‘8’
system.@system[0].cronloglevel=‘5’
system.ntp=timeserver
Br
