Brume 2 traffic monitor/analyser feature
I'm looking to purchase a Brume 2 as my main router, and I'm just wondering if there is any kind of traffic monitor/analyser feature in the web interface?
GL firmware does not support kind of traffic monitor/analyser feature for the time being.
You can install third-party plugins to achieve, like luci-app-statistics
All such plugins have to disable hardware acceleration, so that statistics are accurate.
However if disable hardware acceleration, may affect the speed of the WAN-LAN (NAT).
Hi Bruce, thanks for your response. Are there any current plans to provide a traffic monitor/analyser feature in the default web interface via a firmware update?
I really like the look of the Brume 2. It seems like an excellent wired router option for my home network. It would be great if this feature was available though.
I think there is this feature plan, but it may not be developed quickly, since there are many higher priority task and new products to be done now
Fair enough Bruce. Thanks for your help with this.
