was this test image allowed to be used intentionally not allowing additional packages to be installed or was it in error? please let me know cause I went back to the previous distfeeds.conf and I also point back to openwrt’s rc1 and got nano installed.
3.027 works
I reported same issue for 3.101-0103 on jan 3
in webadmin the following are removed intentionallly but not necessary, guest, wireless just wondered if he should have removed plugins too.
sometimes its good to remove things/functionality to isolate problems.
I also wondered if it was a location issue.
because he had #src glinet_glinet file:/home/zl/gl-image/gl-image/releases-packages/mvebu/glinet
commented out, but it got me to thinking that sometimes during your testing it works within your network but doesn’t get tested from a truly external environment.
I know these are testing/beta bins but somepeople are looking foward to increased functionality use this route and I guess this thread is hear to help them save some time.
fyi i created a guest network on lan1 and separated lan from lan1 and created a guestzone just like the other products hoping gl-webadmin would show guest features like the other routers… didn’t happen.
