Brume 3: DPI - how to review/troubleshoot if specific connection is dropped by the DPI engine
Week one with Brume 3 as the main router in my setup and still learning what’s the best way to do things and utilize its full power.
I’m used to checking which apps/sites get blocked in the AdGuard’s “Settings page” nicely shown under Applications → AdGuard Home, sending me to port :3000, then using the “Query Log”.
How do I see the equivalent logs when using DPI? I feel blind and need some help
Something I need access to Netify for but can’t seem to figure out how to get to it?
Another local port that has the “meat” behind the “DPI magic”?
Or, in another example, what’s the DPI/Netify’s equivalent of the Bark Cloud Services (bark.us) portal if one was to use the Parental Control feature instead?
Unfortunately, the current version does not support showing the details of websites blocked by content filters.
This will be introduced in the new firmware in the future.
For now, the only way to achieve this might be to disable or enable content filters for comparison.
Happy to test when you get closer to releasing some alpha/beta drops.
Thank you for participating in the beta test.
I think we'll post about it on the forum when the firmware is coming out, so stay tuned.
