Brume 3 (MT5000) broken DDNS bug (and part fix)
So.. third time in a month I’ve been woken up by customer emergencies when the VPN tunnel fails. All 3 due to Brume 3’s with DDNS that suddenly stopped working (separate customers / routers). Rebooting the router doesn’t help, but disable/re-enable of DDNS does fix it (after a few minutes for DNS propagation)
I haven’t figured out what’s killing DDNS to begin with, but I have found why it doesn’t self-heal after a basic router reboot.. in short, GL added a new (broken) flock wrapper in this latest firmware.
Symptom: After any reboot, DDNS shows "enabled" in the admin panel but the daemon is not running.
Root cause: A change was made to the hotplug script sometime between builds 224 (SlateAX 4.8.2) and 294 (Brume3 4.8.4) that introduced a flock wrapper.
Old version (working):
/etc/init.d/gl_ddns restart &
New version (broken, build 294):
flock -n /var/run/ddns/glddns.lock /etc/init.d/gl_ddns restart && rm /var/run/ddns/glddns.lock &
The flock call requires /var/run/ddns/ to exist in order to create the lock file. But /var is tmpfs and is wiped on every reboot. The new DDNS init script's boot() function is a no-op (return 0), so nothing recreates this directory at boot. The directory is only created when the DDNS updater script actually runs >>>> but it can't run because flock fails first.
Next is repeat chicken-and-egg problem:
  1. boot() returns 0 > nothing happens
  2. WAN comes up > hotplug fires
  3. flock -n /var/run/ddns/glddns.lock fails silently (no such file or directory)
  4. The restart command inside the flock never executes
  5. DDNS daemon never starts, and no log files + no error in the GUI
How to reproduce:
  1. enable DDNS in GUI
  2. reboot Brume 3
  3. check GUI and DDNS still shows enabled, but:
    /var/run/ddns/ - does not exist
    /var/log/ddns/ - does not exist
    DDNS process - not running
    Syslog DDNS entries - zero
  4. in DDNS GUI: Disable > Apply > Enable > Apply
  5. DDNS is working again.
Conclusion: DDNS is broken on every Brume3 reboot.
FIX: Add mkdir -p /var/run/ddns before the flock call in /etc/hotplug.d/iface/95-gl_ddns
Still not positive what broke it to start with. Have setup a monitoring script for now.
Thanks!
Edits - formatting and late night spelling.
@bruce just experienced this on a another Brume3 today. I can confirm now on 4 separate Brume3s, that after being initialized, GL DDNS is broken upon any subsequent reboot.
Current only fix is to disable (apply) and re-enable the Dynamic DNS in the GUI after reboot.
Posted with workarounds:
https://www.reddit.com/r/GlInet/comments/1s5gruc/important_notice_for_any_brume3_glmt5000_users/
This is a HUGE issue especially for this unit as it's main use case is prob a VPN server.
Did you open a proper ticket with gl.inet support about this?
Agreed, but what is a proper ticket? They have no “official” issue tracker. If they’d give us a proper github then I’d raise an issue.
That said, I do know it’s reported - and they’ve actually had this issue tracked for over a month and didn’t think it was a priority.
This should be a “same day fix, new firmware push” type of issue. Currently the Brume 3 - their premier VPN gateway - is functionally broken for it’s primary purpose.
@will.qiu @bruce someone at GL should be ahead of this. It’s impacting your customers severely right now.
We have created an internal ticket and submitted to R&D.
I find R&D guys have already submitted the fix and will urge them in this ticket to compile the firmware as soon as possible.
Thanks for the support!
Great news. Thank you, @bruce. As further evidence I hit this bug on 2 more separate customer Brume3s again today.
Same exact behavior. On current firmware (4.8.4) the DDNS would silently fail upon reboot. Exact same failure path as the original post..
With both, I manually edited:
vi /etc/hotplug.d/iface/95-gl_ddns
Find the flock line and add mkdir -p /var/run/ddns directly above it:
After patching, rebooted each one and DDNS started automatically. Directories were recreated, daemon runs and hostname update is registered. No manual toggle needed.
Hopefully something they can push this out quick.
Please upgrade to the v4.8.5 beta, and this version has already fixed this issue
Thank you, @bruce . Most of these are customer routers in production (relying on them for daily remote work), so I can’t put them on beta until I’ve had time to test it myself more thoroughly, but I’m glad to hear it’s fixed and appreciate the reply!
In the interim I’ll just keep patching the hotplug. I’m assuming there are likely many new Brume3 customers out there sitting on stable that aren’t going if understand why everything suddenly stops working on the first time their Brume3 reboots while they’re abroad on travel.. and most aren’t going to know how to trace it to a DDNS bug (or how to workaround or that they need beta to fix it).
May want to consider a 4.8.4.x hotfix in the interim if 4.8.5 is going to take a while to migrate to stable.
The firmware runs locally on the router, so we cannot push hotfix updates to it — it isn’t a server or cloud host.
We apologize for any inconvenience. Please upload the beta firmware manually in the GL GUI.
The stable firmware is expected to be released in about three weeks.
I certainly understand that.. but GL can push a small fix update of the firmware to the gl-download center with a version bump, which would then prompt a firmware update notification to everyone via the admin panel - as is normal practice for most software/firmware vendors with critical fixes.
Obviously not ideal, but maybe worth consideration when the new flagship VPN appliance is broken at a core level for it’s primary purpose as a VPN server. Right now, every person having just purchased this and setting it up for VPN use is one reboot away from hitting this failure. I’ve deployed a few dozen of these for customers this past month, so I would assume there’s hundreds more doing the same right now.
GL has pushed version bumps for mostly single features such as AmneziaWG.. I would argue this is significantly more worthy and impacting to customers.
Regardless. I appreciate the response and updates.
I never see stuff or get notified of things from the forum.
I setup and shared my brume a few days ago, is there a ticket I should reference in the notes so support knows why its shared to you.
Hi Yoda,
I was looking for that previous Brume 3 DDNS thread on Discord earlier, but I couldn't find it either. Sorry about this.
Regarding the device sharing, yes, you'll need to email us or DM me on Discord with your Brume 3's MAC address and login password so I can access it via SSH to take a look.
There is a new beta firmware available now, it fixed the DDNS issue for Brume3.
You might want to try that first, and if you're still having issues, feel free to reach out to us again.
Hey @wickedyoda . I’ll hit you on our discord. easy proven fix if you want to stay on stable.
Hi, I have 2 Brume 3 in different locations, both have 2 WAN connections via ethernet, in both cases 1 ISP does not have a public connection however the DDNS service takes the non public ipv4 and ipv6 adresses and the VPN servers cannot be accesed. I would like to suggest that in the DDNS menu, one could select which ethernet connection will have the DDNS adress assigned
@Cocolote are you using it in load balancing mode?
The DDNS client pings an external server to discover it’s public IP, so the server is going to reflect whatever IP address it was pinged from. If you have the router set in Failover mode (the default), then only the primary WAN should be actively routing traffic, so that’s the IP the DDNS (should) reflect.
Yes I am using load balancing mode in both, and as I stated they both always take the non public IP, I have even tried switching the ethernet ports but the result is the same, the not public IP is always the one that the *.glddns.com domain registers and it is not accesible
This is pretty edge case. Most want the DDNS to point back to the primary/preferred interface. In this case it seems your CGNAT iSP is pinning the session for some reason. Could simply be that ISP has the better route to the check server.
Customers I have using multi-wan for a VPN server use it with failover. They have port forwarding set on both upstreams so the DDNS will update to the backup IP when the primary goes down and then they can reach the server again on the fallback and the next update.
If you really want to keep load balance, I’m sure there’s likely a way you could modify the glddns daemon to bind to a specific interface.
Yes its a complicated case, of course in failover it works correctly, but due to the traffic in both locations, load balance is required. I am sure that using Luci there is a way around, (I still have not tried it or found it) however it would be nice to have some “preferred connection” switch in the glinet interface of DDNS for these cases
