Hello all,
I have adguard set up on a Brume but the port offered by the config is 3053 - my router config doesn’t allow you to specify a port for DNS and defaults to 53 - is there any way to configure AdGuard to listen on 53 instead?
To clarify I am using the Brume as if it were an application device for VPN and AdGuard - it is not my main DHCP server.
Many thanks
