Brume cant connect nordvpn thru nordvpn's openvpn config files
hi,
i know brume’s latest version is 3.216 is old.
i cant do what i can do previously: dnld a config file from nordvpn,
upload and connect.
i tried both udp and tcp, both failed.
i found GL inet routers not as good as i used to be/good.
pls advise thanks
ps, i have two nordvpn accounts,
i am using both of them and i am sure i know the password and is working.
i dont know why auth will fail.
thanks
The credentials for Nord OpenVPN are different from login!
Please locate the correct credentials (called “service credentials” if I am right) in your NordVPN dashboard.
that’s new to me.
thank you.
ps, he’s correct, for openvpn login, another set of username and password need to be obtained.
