Any release note of Brume & Flint v.3.212 beta firmware ?
Did anyone try this firmware? Is there anything new added?
I just tried both firmware to my Brume and Flint and don’t know what’s new inside, that’s why I posted here to ask.
So nothing really new added visible in the gui
Nothing new in GUI level as I know, unless it hides deeply
Not release notes here but
It fixed
- repeater “wrong key” bug, especially related to iphone hotspot
- mullvad wiregaurd config pull timeout
- filesharing cannot be installed for some models
- mt1300 multiple ssid encryption bug
- ar750 speedtest crash bug
- other fixes
Added
- Unique wifi SSID and Key support (not affecting product already sold)
So far for flint v.3.212 it works great.
My only issue I had so far was with the automatic mullvad configuration I guess its still in wip?
From what I experienced was this:
after I typed my mullvad code, I received a prompt that all servers get pulled within 30 minutes.
the prompt disappeared before these minutes where expired, and the indication was lost wether it still pulls or not, in the end it didn’t pull.
Im unsure if my keys where full at the moment of trying this, mullvad has a limit of 10 generated keys I could try this again.
I remember that is 5.
Oh you’re right, it should be 5 then I wasn’t sure.
Are there any official release notes or changelog for every firmware update?
That would be great to have as it really helps customers decide if they would need an update or not.
Alternatively, is there a way to obtain this from the git source tree? The tree at GitHub - domino-team/openwrt-cc: openwrt CC with Domino/GL patches doesn’t seem to be tagged.
For example, I would like to know what is the diff between 3.211…3.212.
