Brume GL-MV1000 Tailscale exit node not working
I have two devices connected to tailgate, one my Brume MV1000 and an IPhone 15 pro. I know the exit node is not supported yet, but I followed the following step to advertise the brume as the exit node:
Brume 2 as a Tailscale exit node - #7 by asksimple
When I enable the Brume as the exit node on my iphone, I can’t get to the internet.
Here some of my outputs:
ifconfig tailscale0
tailscale0 Link encap:UNSPEC  HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
          inet addr:100.75.153.71  P-t-P:100.75.153.71  Mask:255.255.255.255
          UP POINTOPOINT RUNNING NOARP MULTICAST  MTU:1280  Metric:1
          RX packets:3920 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1506 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:500
          RX bytes:1448634 (1.3 MiB)  TX bytes:176941 (172.7 KiB)
status
root@GL-MV1000:~# tailscale status
100.75.153.71   gl-mv1000            amb1s1@      linux   -
100.78.196.59   iphone-15-pro        amb1s1@      iOS     active; direct 152.58.235.200:38581, tx 468636 rx 2017188
root@GL-MV1000:~#
root@GL-MV1000:~# ip rule
0:	from all lookup local
48:	from all to 27.191.208.0/20 lookup main
49:	from all to 192.168.8.0/24 lookup main
50:	from all to 100.100.100.100 lookup 55
51:	from all fwmark 0x100000/0x100000 lookup 51
52:	from all fwmark 0x80000/0x80000 lookup 52
53:	from all fwmark 0x60000/0x60000 lookup 53
1001:	from all iif wan lookup 1
1310:	from all fwmark 0x800000/0xff0000 lookup main
1330:	from all fwmark 0x800000/0xff0000 lookup default
1350:	from all fwmark 0x800000/0xff0000 unreachable
1370:	from all lookup 55
2001:	from all fwmark 0x100/0x3f00 lookup 1
2061:	from all fwmark 0x3d00/0x3f00 blackhole
2062:	from all fwmark 0x3e00/0x3f00 unreachable
32766:	from all lookup main
32767:	from all lookup default
root@GL-MV1000:~#
root@GL-MV1000:~#  ip route show table 55
100.78.196.59 dev tailscale0
100.100.100.100 dev tailscale0
root@GL-MV1000:~#
default via 24.191.208.1 dev wan proto static src 24.191.212.30 metric 10
10.0.0.0/24 dev wgserver proto kernel scope link src 10.0.0.1
27.191.208.0/20 dev wan proto static scope link metric 10
100.64.0.0/10 dev tailscale0 scope link
192.168.8.0/24 dev br-lan proto kernel scope link src 192.168.8.1
root@GL-MV1000:~#
I’m able to ping from the tailscale0 interface:
root@GL-MV1000:~# ping 8.8.8.8 -I 100.75.153.71
PING 8.8.8.8 (8.8.8.8) from 100.75.153.71: 56 data bytes
64 bytes from 8.8.8.8: seq=0 ttl=58 time=10.201 ms
Any help will be appreciated.
Try hardcoding the connection parameters:
hi,
Please also refer to Tailscale on XE3000 to route all traffic through remote MT3000 running tailscale - #24 by jddebug
