Brume mv1000 crash
For now it looks good but if you have adguard home and wireguard client active it use the dns from adguard home upstream if I remember correct last firmware it used wireguard client dns
Found a solution just add a public dns on the device which use wireguard and it will automatically use the dns from the Vpn provider
I haven’t yet updated the firmware, but resolved the memory leak and resulting instability by disabling ‘gltertf’ - see this thread What is gltertf and why does it use tons of RAM? - #6 by tve
You can just upgrade the firmware. It solves exactly the gltertf problems.
If you use adguard and vpn at the same time, DNS settings of Adguard will take the priority. It needs that to work properly.
36 hours with new firmware no memory leak. Also Nordvpn client on reboot connected instantly where as before you had to click the connect and disconnect button in the Gli.net app 2 times or more before a successful vpn connect occurs.
Thanks!
