Is it possible to configure lan0 or lan1 to have VLAN tagging on brume? If so how? (I haven’t used VLANs on openwrt.) Thanks!
You can read about that here:
One “gotcha” is that many switches under GL.iNet or OpenWrt firmware use a “VLAN table” so you have to explicitly specify the VLAN tag (“vid”) over the limit. Depending on device, that commonly can be 16 or 128.
I haven’t checked on the Brume (and Ubuntu is configured completely differently from GL.iNet / OpenWrt), but, here from a different device is how you can tell (this device has a table of 128 entries):
jeff@garage:~$ swconfig list
Found: switch0 - mdio-bus.0
jeff@garage:~$ swconfig dev switch0 help
switch0: mdio-bus.0(Atheros AR8327), ports: 7 (cpu @ 0), vlans: 128
--switch
Attribute 1 (int): enable_vlan (Enable VLAN mode)
Attribute 2 (none): reset_mibs (Reset all MIB counters)
So, for this device, VLAN 128 or higher would need the vid explicitly specified.
Some good rules of thumb are:
- VLAN 1 or VLAN 2 are typically used by GL.iNet / OpenWrt “stock” config – be careful with them
- Many consider mixing tagged and untagged packets on the same wire poor practice
You can add this part of config to /etc/config/network
config interface 'wan_internet'
option ifname 'wan.10'
option proto 'dhcp'
config interface 'wan_iptv'
option ifname 'wan.20'
option proto 'dhcp'
config interface 'wan_voip'
option ifname 'wan.30'
option proto 'dhcp'
The run
/etc/init.d/network restart
And run:
ip link set wan.20 type vlan egress 0:4
to set priority.
Hehe - lots of rules of thumbs there - so unlike most people that have two thumbs.
Setting up VLAN’s - consider using ID’s above 1000 (note that Apple Airports use VLAN1003 for extending secondary SSID, BTW) to avoid conflicts with repurposed consumer router/AP’s
Thanks for the replies, turns out the vlan stuff was easy, I was just looking at the wrong guide…
In /etc/config/network I changed the ifnames for the interface 'lan' to option ifname 'lan0.1 usb0' to have the “lan” on vlan1 of lan0. Also added a guest network interface using:
config interface 'guest'
option ifname 'lan0.3'
option proto 'static'
option hostname 'gw2guest'
option ipaddr '192.168.10.0'
Then go into the luci firewall UI and set-up the guest interface with its own zone, etc.
care to share you whole /etc/config/network file with full vlan configs
Sure:
/etc/config/network
config interface 'loopback'
option ifname 'lo'
option ipaddr '127.0.0.1'
option netmask '255.0.0.0'
config globals 'globals'
option ula_prefix 'fd62:1980:0000::/48'
config interface 'lan'
option type 'bridge'
option ip6assign '60'
option hostname 'gw2'
option ipaddr '192.168.0.1'
config interface 'wan'
option ifname 'wan'
option proto 'dhcp'
option hostname 'GL-MV1000-f68'
option metric '10'
config interface 'wan6'
option ifname 'wan'
option proto 'dhcpv6'
option auto '0'
option reqaddress 'try'
option reqprefix 'auto'
config interface 'lan0'
option ifname 'lan0'
option macaddr '94:00:00:00:00:00'
config interface 'mgmt'
option ifname 'lan1'
option hostname 'gw2mgmt'
option ipaddr '192.168.0.61'
config interface 'lan1'
I currently only have two vlans, ‘lan’ and ‘guest’, both on the ‘lan0’ interface.
