Brume mv1000, imagebuilder is not working
I was trying to build an image with the imagebuilder for the brume:
git clone https://github.com/gl-inet/imagebuilder gl_imagebuilder
cd gl_imagebuilder
./gl_image -p mv1000-emmc
Ends up with a lot of packages that can’t be find (this is the last entry):
    opkg_download: Failed to download http://download.gl-inet.com/releases/packages-3.x/mvebu/base/uci_2019-09-01-415f9e48-3_aarch64_cortex-a53.ipk, wget returned 8.
 * opkg_install_pkg: Failed to download uci. Perhaps you need to run 'opkg update'?
 * opkg_install_cmd: Cannot install package uci.
 * opkg_install_pkg: Package size mismatch: uclient-fetch is 7377 bytes, expecting 7365 bytes
 * opkg_install_cmd: Cannot install package uclient-fetch.
Makefile:152: recipe for target 'package_install' failed
make[2]: *** [package_install] Error 255
Makefile:111: recipe for target '_call_image' failed
make[1]: *** [_call_image] Error 2
Makefile:195: die Regel für Ziel „image“ scheiterte
make: *** [image] Fehler 2
Failed to build gl-mv1000-emmc...
Locks like an issue with the feeds config or the repository.
@wellnw @robotluo @lancer
Hi kirdes:
The problem has been solved.
Now,You could exec:
1,rm imagebuilder/3.1/openwrt-imagebuilder-mvebu-emmc_mv1000_3.1/dl -rf
2,gl_image -p mv1000-emmc.
