Also, is it possible for the router in repeater mode to get the signal from 5ghz hotel wifi
and broadcast it devices on 5ghz as well, ensuring max speeds?
With the Brume-W you can only receive the 2.4 Ghz, you can rebroadcast to 5 Ghz using
a WiFi dongle like the ALFA AWUS036AC, but You cannot use the dongle as receiver.
I would recommend using the new Beryl dual band. I just received it.
I noticed that the WiFi discovery search is very fast compare to the Brume.
I’m a Comcast customer and in my area the Comcast hotspots are quite available but use 5 Ghz.
Typically I was able to get a WiFi download from 10 to 50 Mbps and upload from 1 to 6 Mbps.
I hope I answer your question. Also the GL-inet customer support is very helpful and fast to reply.
Note: If you have different routers I would recommend using different IP base address for each
like 192.168.10.1 and so on, instead of the default 192.168.8.1.
Also connecting you phone directly using an USB Ethernet Adapter is even more practical.
