BUG: Collie Lock-Up
With a new SIM, I was blocking Bands one by one in an attempt to find the one which was fastest. I’m guessing I blocked all available bands, which then left the router unresponsive, necessitating a reset.
Sure, not a major problem but surely this shouldn’t happen.
Hi @Happi I couldn't reproduce the problem.
May I know if there is any error message displayed in the admin panel? Are you using the original power adapter? What's the current firmware version?
Thanks for taking the time to reply.
Firmware is latest (see screenshot).
From memory, no error message, the GUi just freezes and (from memory) I just get a time-out message.
No, the power supply is not original (using USB power delivery) but the power rating is more than sufficient.
Are you still able to reproduce it? If so, could you share the device logs and send to me for investigation?
I had another go and the answer is no, I can’t reproduce it.
Seems like it was a one-off, so apologies and thanks for your attention.
Understood. Thanks for your updates.
