It is better illustrated by the following terminal output:
# /etc/init.d/S99kvmd-nginx reload
停止 kvmd-nginx: 成功
启动 kvmd-nginx: /etc/init.d/S99kvmd-nginx: line 46: /etc/init.d/S50nginx: not found
成功
停止 kvmd-nginx: 成功
成功
That mistake won't affect anything. We will remove this error in the next version
Could you tell me how to let nginx reload the certificate?
restart nginx
/etc/init.d/S99kvmd-nginx restart
That’s why I discovered this bug. It affects me!![]()
New beta test firmware: 1.4.0 beta1 for RM1(Comet) We will fix this issue in version 1.4, please try this beta firmware
Thanks for the opportunity. I appreciate your offer of a beta version.
However, the GL-RM1 is deployed in a production environment. I rather not to mess with beta software. I will wait until a well tested stable version.
In the meantime, I get by with a patched script written by myself.
It would be great if you put the reload step into your document.
