Main Network: VLAN 1, 192.168.50.0/24, LAN + Main SSID
Guest Network: VLAN 10, 172.16.10.0/24, LAN + Guest SSID (used as my management network)
IoT Network: VLAN 40, 192.168.60.0/24
Servers: custom subnet, VLAN 30, 172.16.30.0/24, LAN interface only
The LAN port is a trunk to a managed switch: VLAN 1 untagged, VLANs 10 and 30 tagged.
Steps to reproduce
Everything working: devices on all VLANs reachable.
Turn the Guest Network off and back on with the toggle in the admin panel.
Expected: Only the guest SSID goes down and comes back up. Other networks are unaffected.
Actual: Every device on the Servers network (VLAN 30) drops offline and is unreachable from other networks and from the router itself. VLAN 1 and VLAN 10 keep working over the same trunk port.
In LuCI (Network → Interfaces), br-vlan30 is still up with 172.16.30.1/24, but it has no bridge ports attached. br-guest and br-lan still have their ports. It looks like re-applying the guest network rebuilds the bridges and doesn’t re-add [port name, e.g. eth1.30] to br-vlan30.
The firewall zones and rules were unchanged and correct.
Workaround
In Network → Subnet, open Edit on the Servers subnet and click Apply without changing anything. This rebuilds br-vlan30 with the LAN port attached, and VLAN 30 works again immediately.
Could you please export a configuration backup using the guide below and send it to us via private message? This will help us test with your exact configuration and investigate further.
To send a private message, click our avatar and then the Message button.
Thanks for testing. I’ll send you the configuration backup via private message.
In the meantime I dug deeper on the router over SSH (Together with Claude Code), and I can now reproduce it reliably. The detail that probably makes the difference: Mesh is enabled (controller, traffic separation on, ts_guest_vid=4002), even though I don’t use any mesh satellites, and the LAN port is a trunk (pvid 1, tagged 10 30).
Setup
GL-BE3600, firmware 4.10.1
Custom subnet “Servers”: network.vlan30, VLAN ID 30, br-vlan30 with port eth1.30
Guest subnet on VLAN 10 (br-guest: eth1.10, eth1.4002, wlan01)
gl-mesh enabled as controller, ts_enabled=1, ts_guest_vid=4002, ts_iot_vid=4003
Physical switch set to Wi-Fi → Guest Wi-Fi
Reproduction (100% so far)
Toggle Guest Wi-Fi off or on, from the web UI or with the physical switch.
~5–10 seconds after qca-wifi-configurator finishes (“first setup … enabled AP VAP missing, recreate: wlan01”), the kernel VLAN device eth1.30 is deleted.
VLAN 30 is down until the interface is restarted.
What happens at runtime
/proc/net/vlan/config afterwards only contains eth1.10. Both eth1.30and eth1.4002 are gone, although both are still defined in /etc/config/network.
netifd does not notice: ubus call network.device status '{"name":"eth1.30"}' still reports present: true, br-vlan30 still lists eth1.30 as a member, and vlan30 stays “up” with its IP. So the UI shows everything fine while every device in VLAN 30 is unreachable.
During the guest-off reload, a VLAN device eth1.20 briefly appeared in br-guest a few times (it is not in any UCI config). Each time it appeared, eth1.30 was removed again; netifd recreated eth1.30 and it got deleted again within a second.
Only eth1.10 (the GL-managed guest VLAN) survives. It looks like the guest-network / mesh traffic-separation rebuild removes all VLAN sub-interfaces on the LAN trunk port that it doesn’t manage itself, including VLANs belonging to custom subnets.
Relevant log (guest Wi-Fi turned on from the UI, 08:45):
08:45:20 qsdk-wifi: first setup
08:45:20 qsdk-wifi: enabled AP VAP missing, recreate: device=wifi0 ifname=wlan01
08:45:23 br-guest: port 2(wlan01) entered forwarding state
08:45:24 br-guest: port 3(eth1.4002) entered forwarding state
08:45:25 netifd: VLAN 'eth1.4002' link is up / down / up / down / up
08:45:28 netifd: VLAN 'eth1.30' link is down
08:45:28 br-vlan30: port 1(eth1.30) entered disabled state
08:45:28 device eth1.30 left promiscuous mode
08:45:28 netifd: Interface 'vlan30' has link connectivity loss
08:45:30 netifd: VLAN 'eth1.30' link is up
08:45:30 netifd: VLAN 'eth1.30' link is down
What does / doesn’t recover it
Re-applying the Servers subnet in the UI without changes: no effect (only tertf re-registers, netifd does nothing).
Changing a DHCP option of the subnet (lease time) and applying: no effect.
Changing a network-level setting of the subnet: recovers it (vlan30 is restarted).
ifup vlan30 over SSH: recovers immediately.
Confirmed: mesh is the trigger. After disabling Mesh in the UI, I toggled Guest Wi-Fi off and on again (same “first setup … recreate wlan01” path in the log). eth1.30 stayed in br-vlan30 both times and VLAN 30 kept working. With Mesh enabled, every guest toggle broke it.
Since I don’t use mesh satellites, I’m keeping Mesh disabled as my workaround. But anyone using Mesh together with a custom VLAN subnet on a trunk port will hit this: it would be great if the mesh traffic-separation rebuild could leave VLAN devices of custom subnets alone (or if netifd were told to re-sync them afterwards).
Happy to run any additional commands or test builds.
Apologies for the confusion, and thanks for again taking the time to test this.
After my previous reply I kept testing (again together with Claude Code), and I can no longer reproduce the issue. Since I disabled and re-enabled Mesh, I've toggled Guest Wi-Fi several times, both from the web UI and with the physical switch, and eth1.30 stays in br-vlan30 every time. VLAN 30 keeps working, with Mesh and traffic separation enabled.
So it looks like gl-mesh / prplMesh had ended up in a bad state after ~34 days of uptime, and restarting Mesh cleared it. That would also explain why you couldn't reproduce it on a fresh unit.
I haven't sent the backups yet, since they were taken after the mesh restart and probably won't help you reproduce it. I do have them (one with Mesh enabled, one with it disabled), so if you'd still like them, just let me know and I'll send them via private message.
If the problem comes back after a longer uptime, I'll update this thread with the logs and how long the router had been running.
Thank you for the detailed explanation, additional testing, and follow-up.
Since the issue is no longer occurring, there's no need to send the configuration backups or take any further action for now. We'll try to reproduce the behavior internally using the details you've shared and keep an eye out for similar reports.
If it happens again, or you encounter any other issues, please feel free to let us know. Thanks again for your help!
