[BUG] GL-E5800 Mudi 7 — LAN DHCP DNS setting is lost after reboot
Summary
On a GL.iNet Mudi 7 (GL-E5800), a custom DNS server entered in the LAN DHCP settings is saved and active before reboot. After reboot, DHCP option 6 is absent from the persistent configuration and the DNS field in the GL.iNet interface is empty.
The user reports that the behavior is reproducible. This investigation captured one complete before-and-after reboot transition.
Environment
Item Value
Device GL.iNet Mudi 7 / GL-E5800
GL.iNet firmware 4.8.5
OpenWrt 23.05.4 r24012-d8dd03c46f
Kernel 5.15.170-perf
Internet connection Cellular
VPN WireGuard
LAN 10.100.1.0/24
Configured DHCP DNS server 10.10.70.100
The DNS server is on a private network reachable through WireGuard. This is the setup in which the problem was observed; it has not been established as the cause.
Steps to reproduce
  1. Connect the router to the Internet through its cellular connection.
  2. Enable the WireGuard client that provides access to 10.10.70.100.
  3. In the GL.iNet LAN DHCP advanced settings, enter 10.10.70.100 as the first DNS server and apply the configuration.
  4. Confirm that uci show dhcp.lan contains:
dhcp.lan.dhcp_option='3,10.100.1.1' '6,10.10.70.100'
  1. Confirm that uci changes dhcp returns no output.
  2. Reboot the router normally.
  3. Inspect the LAN DHCP DNS field and run uci show dhcp.lan and uci changes dhcp after boot.
Expected result
The committed LAN DHCP DNS server remains configured after reboot.
Actual result
After reboot, DHCP option 6 is absent and the DNS field in the GL.iNet interface is empty. uci changes dhcp returns no output, showing that the post-reboot state is persistent rather than an uncommitted change.
The GL.iNet LAN RPC returns an empty DNS list, and the generated dnsmasq configurations do not contain option 6.
Captured before-and-after state
Before reboot:
GL.iNet LAN RPC:
{"interface":"lan","dns":["10.10.70.100"]}
Generated dnsmasq configuration:
dhcp-option=lan,6,10.10.70.100
After reboot:
dhcp.lan.dhcp_option_force='26,1472'
GL.iNet LAN RPC:
{"interface":"lan","dns":[]}
Generated dnsmasq configurations no longer contain option 6.
Relevant configuration diff:
config dhcp 'lan'
list dhcp_option '3,10.100.1.1'
- list dhcp_option '6,10.10.70.100'
+ list dhcp_option_force '26,1472'
The persistent DHCP configuration changed during boot. The available evidence does not identify the exact process responsible.
Thank you for providing the detailed information and the steps to reproduce this issue.
We tested this behavior locally on the GL-E5800 and were able to reproduce the same issue: the custom DNS server configured in the LAN DHCP settings works normally before reboot, but the setting is lost after restarting the device.
We have recorded this issue and forwarded it to our development team for further investigation.
We will update this thread once we have further progress.
Thank you for your understanding and support.
this is affecting me as well and really annoying.
This means, after every boot of the router, you need to login into the admin panel and reset the DNS settings for DHCP.
Additionally it might happen, that in the meantime a connected client tries to run some DNS queries, which fail and get cached in failed state. Then you need to reset/restart these clients as well.
So basically this bug wastes a huge amount of time and makes me not want to use the router, unless i really really have to.
Sorry for the inconvenience. We have reproduced this issue and are working on a fix.
As a temporary workaround, please connect to the router through SSH and run:
uci delete 'qcmap_lan.@profile[0].ippt_bridge_context'
uci commit qcmap_lan
Afterward, the LAN DHCP DNS settings should be configurable as expected and should persist after a reboot.
To undo the change:
uci set qcmap_lan.@profile[0].ippt_bridge_context='0'
Same issue here on a GL-E5800 (Mudi 7), firmware 4.10.0 (OpenWrt 23.05.4). Unfortunately the workaround does not help in our case.
What I did:
  1. uci delete 'qcmap_lan.@profile[0].ippt_bridge_context' and uci commit qcmap_lan
  2. Entered the custom DNS server again in the GL web UI (LAN → DHCP). Before the reboot it was active: dhcp.lan.dhcp_option='6,<dns-ip>', and dnsmasq had dhcp-option=lan,6,<dns-ip>.
  3. Rebooted.
Result: ippt_bridge_context did not come back, but /etc/config/dhcp is rewritten again during boot. The dhcp_option entry is gone and the DNS field in the UI is empty. The DHCP range set in the UI survives the reboot, only the DNS server is lost.
Setup: router online via repeater (Wi-Fi client) plus cellular as backup. The DNS server is in a private network reachable through a WireGuard client.
Is there an updated workaround or a firmware version with a fix?
Your result confirms that the documented ippt_bridge_context workaround does not resolve this variant on firmware 4.10.0. I’m not aware of a verified replacement workaround or a firmware version with this fix yet.
As a targeted check, temporarily disable the WireGuard client, configure a normal reachable DNS server (for example, your preferred public DNS), and reboot once. If the DHCP DNS entry still disappears, this helps rule out an interaction with the WireGuard/private route; if it remains, the VPN or routing setup is likely involved. Please report that result in this topic so it can be compared with the reproduced case.
Disabling the WireGuard client is not an option for us, not even as a test setup we could run with. The VPN tunnels are the main reason we use this router. The DNS server our clients need is only reachable through WireGuard, and a router that loses its LAN DHCP DNS setting whenever VPN is in use is basically useless for our purpose. If this cannot be fixed, we would rather stop using the Mudi 7 and switch to a different manufacturer.
Some more details that may help the developers:
  • The DHCP range set in the UI survives a reboot, only the DNS entry (dhcp_option 6) is removed.
  • /etc/config/dhcp is rewritten about 30–40 seconds after boot.
  • For now we run a small script from /etc/rc.local that re-adds dhcp.lan.dhcp_option='6,<dns-ip>' and reloads dnsmasq after boot. That works, but it is only a workaround and should not be necessary.
We would appreciate a proper fix in the firmware.
Thank you for providing the additional details and sharing your test results.
We tested the previously suggested ippt_bridge_context workaround locally on firmware v4.10.0, and it worked in our testing.
We have reported this issue to the relevant development team and working on a fix.
Thank you again for your feedback and understanding.
@charles2 thanks for testing. Unfortunately the ippt_bridge_context workaround does not solve it on our GL-E5800 (firmware 4.10.0). Here is everything we found over the last two weeks, maybe it helps the developers:
1. The DHCP DNS entry is lost not only at boot, but also during normal operation
  • ippt_bridge_context was deleted and committed (it did not come back), the DNS server was entered again in the UI, and the router was rebooted → dhcp_option 6 was gone again. /etc/config/dhcp is rewritten roughly 30–40 s after boot.
  • It also happens without a reboot: after about 40 minutes of uptime, /etc/config/dhcp was rewritten again and the DNS entry was removed. At the same moment the log shows QCMAP ... backhaulCommonConfig.sh, so it looks like a cellular reconnect makes QCMAP re-apply its LAN config and overwrite /etc/config/dhcp.
  • Only the DNS entry is lost. The DHCP range set in the UI survives, probably because qcmap_lan knows the range but has no field for a DNS server.
2. “Force DNS” turns itself back on after boot
  • In GL-DNS (gl-dns-v2), force_dns was set to 1 by itself about 6 minutes after a normal boot (/etc/config/gl-dns-v2 modified, nobody touched the UI). We had set it to 0 a few days earlier.
  • With force_dns=1, every client DNS request is redirected to the router (nft inet dns_table / dns_redirect: redirect to :53). The router’s own traffic does not go through the WireGuard tunnel, so it cannot reach our private DNS server and falls back to the public one. Result: public names resolve, internal names (behind WireGuard) do not.
  • Note: just setting force_dns=0 and restarting gl_dns is not enough. The redirect rule stays until /etc/init.d/firewall reload.
3. Our current workaround (works reliably, but should not be necessary)
A small script runs from /etc/rc.local after boot and from cron every minute. It:
  • re-adds dhcp.lan.dhcp_option='6,<dns-ip>' and reloads dnsmasq if the entry is missing
  • sets force_dns=0, restarts gl_dns and reloads the firewall if force DNS is on or the redirect rule exists
Tested: removing the DNS entry or force DNS being switched on by the firmware is corrected within one minute.
4. Two related things we noticed (in case they are useful)
  • “Full Cone NAT” (/etc/init.d/fullconenat) adds a MASQUERADE rule on every up interface at boot, including the WireGuard clients, even when masquerading is disabled for that VPN in the UI. We need routed (non-NAT) site-to-site traffic, so we remove those rules by script.
  • After a cellular reconnect, /proc/gl-kmwan/status sometimes shows the wrong netdev for modem_cpu (rmnet_data1 while the default route actually uses rmnet_data0).
Setup: GL-E5800, firmware 4.10.0 (OpenWrt 23.05.4), internet via cellular (repeater optional), two WireGuard clients with policy routing (include lists), DNS server in a private network reachable only through WireGuard.
Is there an ETA for a firmware with a fix? We are happy to test a beta or snapshot.
One more issue on the same GL-E5800 (firmware 4.10.0), probably related, because it is again triggered when QCMAP re-applies its configuration:
The router itself becomes unreachable through the WireGuard tunnel after the WAN connection changes
Setup: two WireGuard clients with policy routing (include lists). wgclient1 goes to our home network, wgclient2 to the office. Internet access is via cellular or repeater, which changes while travelling.
What happened:
  • The router switched to a new repeater Wi-Fi. At that moment the log shows QCMAP ... backhaulCommonConfig.sh rebuilding the firewall.
  • After that, the router’s LAN IP was not reachable from the home network any more (ping, SSH, web UI, SNMP). The tunnel itself was up: the tunnel IP of wgclient1 still answered, and clients behind the router could still reach the home network.
  • Cause: in inet vpn_table, the rule wgclient1_in_new_connmark was missing after the rebuild, while wgclient2_in_new_connmark was still present. Without it, the router’s own replies to connections that came in through wgclient1 are not marked. They are routed via the main table (default route over the repeater) instead of back through the tunnel, and get lost:
    ip route get <home-ip> from <router-lan-ip>   ->  via <repeater-gw> dev wlan4   (should be dev wgclient1)
  • A side effect of the same routing design: the router’s own traffic never uses the tunnel, so the router itself cannot reach a DNS server that is only reachable through WireGuard. This is also why “force DNS” breaks internal name resolution (see my previous post).
Thank you for the detailed reports and for sharing your findings with us.
Regarding the DHCP DNS issue, we have checked with the relevant team, and a beta firmware addressing this issue is tentatively expected later next week.
We have also forwarded your report about the WireGuard connectivity issue to the relevant team for further investigation.
Thank you again for your feedback and support.
Update from OP: where the DNS entry gets removed, and a workaround
Additional observation: on 4.10.0 the LAN DHCP DNS entry was also gone overnight without a reboot, probably after the device woke from standby.
Where it happens. In both 4.10.0 and 4.10.2 beta7, /lib/netifd/rmnet.script → setup_ipv4_lan() (non-IP-passthrough branch) does this when the cellular interface comes up:
delete_dhcp_option_list $downstream 6
dns_mode=$(uci get qcmap_current_lan_config.$downstream.dns_mode)
# option 6 is only re-added if dns_mode is 2 or 3
util_add_mtu_options $profile 4   # adds dhcp_option_force '26,1472', then: uci commit dhcp
On my device qcmap_current_lan_config.lan.dns_mode is 1 even though a DNS server was set in the UI, so option 6 is removed and not added back. Removing option 6 and adding dhcp_option_force '26,1472' is exactly the diff from my first post. On my device, /etc/config/dhcp was rewritten again both after ifup modem_cpu and after a reboot.
4.10.2 beta7 (compared the system images; not installed): reset_ippt_lan_params() in /etc/data/ippt.sh now only removes option 6 when the LAN shows IP-passthrough traces. That is the function the ippt_bridge_context workaround bypasses. rmnet.script is unchanged compared to 4.10.0. @charles2 can you may confirm whether the upcoming fix also covers the rmnet.script path?
Workaround (tested on 4.10.0): put option 6 into /etc/dnsmasq.conf instead of /etc/config/dhcp. /etc/init.d/dnsmasq includes this file via --conf-file.
echo 'dhcp-option=lan,6,<dns-ip>' >> /etc/dnsmasq.conf
uci -q del_list dhcp.lan.dhcp_option='6,<dns-ip>'
uci commit dhcp
/etc/init.d/dnsmasq restart
Result here: after ifup modem_cpu and after a reboot, my client still received <dns-ip> via DHCP, although /etc/config/dhcp had been rewritten.
:warning: Please note:
  • With this workaround, the DNS field in the GL web UI shows empty, even though the DNS server is still handed out to clients. Keep that in mind when troubleshooting later.
  • Configure the DNS server in one place only: don’t enter it in the UI as well while the line is in /etc/dnsmasq.conf. To change it, edit the file and restart dnsmasq.
  • Remove the line again once you are on a firmware with the fix.
  • Not tested: whether /etc/dnsmasq.conf survives a firmware upgrade with “keep settings”.
Thank you for sharing your findings and the detailed feedback.
We will forward this information to the relevant team for further investigation and update this thread when we have more information.
Thank you again for your testing and feedback.
