[Bug] GL-MT3600BE (4.9.2): gl_tailscale forces --accept-dns=false and server=/ts.net/100.100.100.100 into dnsmasq.conf -> DNS loop storm with OpenClash
Device / Firmware: GL-MT3600BE, firmware 4.9.2, Tailscale 1.92.5
/usr/bin/gl_tailscale md5: 59b3e886aba441c76de46c39d0417617
Summary
/usr/bin/gl_tailscale always runs tailscale up --reset ... --accept-dns=false (line 331), then appends server=/ts.net/100.100.100.100 to /etc/dnsmasq.conf (lines 141, 150-151) and restarts dnsmasq.
If the router also runs a transparent proxy with DNS hijacking (OpenClash, mosdns, AdGuard Home, etc.), the router's own packets to 100.100.100.100:53 are REDIRECTed back to dnsmasq, so every *.ts.net query loops:
dnsmasq -> 100.100.100.100 -> dnsmasq -> ... until it dies.
Observed: ~3000 q/s, dnsmasq at 100% CPU, ALL DNS (including domestic sites) delayed by seconds.
The rule cannot be disabled: line 141 only greps for the string ts.net/100.100.100.100, so the only way to turn it off is to keep a dummy commented line containing that text.
Steps to reproduce
  1. Enable Tailscale in the GL admin panel (firmware 4.9.2).
  2. Install OpenClash (or anything that hijacks router-originated DNS to 100.64.0.0/10).
  3. From a LAN client resolve any *.ts.net name -> loop; check dnsmasq CPU in top.
Expected
  • A UCI switch to disable the dnsmasq injection (e.g. tailscale.settings.dns_inject='0'), and/or an option to allow --accept-dns=true instead of hard-coding --accept-dns=false with --reset.
  • Write the rule to a drop-in file (conf-dir /tmp/dnsmasq.d/) instead of appending to /etc/dnsmasq.conf, so it can be overridden and survives upgrades cleanly.
  • Optional: make the dhcp.@dnsmasq[0].domain override (line 155) configurable too; it breaks local *.lan names.
Current Workaround
Keep the line in /etc/dnsmasq.conf but comment it out (so the grep still passes), and resolve *.ts.net inside OpenClash via nameserver-policy -> 100.100.100.100.
