I have two routers:
- GL X-3000: Serves as the primary router to which clients connect. It runs wireguard.
- GL MT-3000: Serves as a drop-in gateway. It also runs wireguard.
If connection with wireguard servers is established everywhere, the output to the Internet works like this:
Clients->X-3000(Wireguard)->MT-3000(Wireguard).
But if connection with wireguard server drops at drop-in gateway, all traffic from clients goes only through the first wireguard (X-3000). But at the same time, if you simply disconnect drop-in gateway - there is no Internet access, as it should be.
On both routers ‘Block all non vpn traffic’ function is enabled.
How can I make it so that if the connection on the second router, which serves as a drop-in gateway, drops connection to the wireguard -> clients do not have access to the Internet (lockdown mode)?
