After installing OpenWrt image, and then reverting to original firmware, the original web-interface is not present (just luci).
After installing bind-host this issue got resolved and everything appeared.
This error message appeared after install ddns.
BusyBox's nslookup and hostip do not support to specify to use TCP instead of default UDP when requesting DNS server! - You should install 'bind-host' or 'knot-host' or 'drill' package for DNS requests.
I would install GL.iNet firmware by Uboot or install a openwrt version that is known to work. If you want to continue to use Openwrt you might try posting on their forum board
