Device: GL-MT6000 (Flint 2)
Firmware: 4.11.3
Packages: gl-sdk4-network-quality git-2026.295.26258-1103a6f-1, AdGuard Home 0.107.73
Setup:
- AdGuard Home on, "AdGuard Home Handle Client Requests" on, upstream_mode: parallel, DoT upstreams
- WireGuard VPN client; GL.iNet's VPN policy routes AdGuard Home's own traffic (process group 20000) through the tunnel, so the DNS providers only see the VPN exit IP
- Network Quality on (default off)
What happens
Network Quality reads upstream_dns from /etc/AdGuardHome/config.yaml and probes each entry, plus the WAN DHCP resolvers, about once per second with network-quality-dns-lookup <server> google.com 1 1000, i.e. dig @<server> google.com.
1. Per-domain upstream entries are passed to dig unparsed. With these upstreams:
[//]192.168.8.1
[/lan/]192.168.8.1
[/example.com/]tls://1.1.1.1
dig treats the whole string as a server hostname and tries to resolve it through /etc/resolv.conf (the ISP resolvers). A capture on the WAN interface shows queries like
A? [//]192.168.8.1.
A? [/lan/]192.168.8.1.
several times per minute, each answered NXDOMAIN. Running the probe by hand:
# network-quality-dns-lookup "[//]192.168.8.1" google.com 1 1000
1 -1 dig: couldn't get address for '[//]192.168.8.1': not found
The intended server (192.168.8.1) is never probed.
2. Secondary, possibly by design: the probes measure a different DNS path than the one clients use.
If Network Quality is meant to test the WAN uplink only, this is expected; it is still worth knowing for users who route AdGuard Home through a VPN.
Path clients use: client -> AdGuard Home -> DoT through the VPN tunnel -> upstream
Path that is probed: router -> ISP resolvers (to resolve the upstream hostname)
-> unencrypted UDP/53 directly over WAN -> upstream
For tls://dns.quad9.net and tls://security.cloudflare-dns.com, the probe skips AdGuard Home, the VPN policy and the configured encryption. As a result:
- the DNS Lookup latency shown does not describe the DNS the clients actually get,
- the upstream providers see the user's real WAN IP every few seconds, although the VPN policy is set up so they only ever see the VPN exit IP, and
- the ISP resolvers get queries every second (google.com, the upstream hostnames and the unparsed entries from point 1), although AdGuard Home handles all client DNS.
Expected
- Strip the
[/domains/]prefix of AdGuard Home upstream entries (or skip such entries) before probing. - Secondary: when AdGuard Home's traffic is routed through a VPN, either probe its upstreams the same way (VPN policy, configured protocol, hostnames via AdGuard Home's bootstrap DNS), or leave them out of a WAN-only test.
How to reproduce
- Add a per-domain upstream such as
[//]192.168.8.1to AdGuard Home's upstream DNS servers. - Enable Flow Control -> Network Quality.
- On the router run
tcpdump -ni <wan interface> udp port 53and watch for the bracketed names and for plain google.com queries to the AdGuard Home upstream IPs.
