when connecting a wireguard client the main screen with the router illustration shows vpn as disconnected although the connection is up and working fine;
under “Custom DNS Server” settings, when selecting “DNS over TLS” and picking Cloudflare, the setting seems to revert back to NextDNS upon screen refresh and reboots (possibly just display issue);
and while I am here, a humble minor feature request -
is it possible to have the graphic on the main screen change when the connected vpn type is OVPN vs WG? even a simple “w” or “g” overlay on the shield might be great.
some folks, like me, use both protocols especially when travelling
guessing if your seeing nextdns settings then your running snapshot.
there is a newer bin in testing although it actually shows a lower bin number of 3.102… it is an april 3rd not the 3.103 march 2nd. I’m going by file date not revision… I guess I could be wrong.
hi @alzhao,
thanks for the reply but what about the 1st bug i mentioned? (visual representation of the wireguard connection up and running. see my first post - item 1)
that’s cool @alzhao but it is not the device nor the version I was reporting the bug on
if what you are saying is that it is positively resolved on 104 and it would eventually get released for the AR750 then i’ll happily wait.
hi @wellnw.
downloaded, tested and confirmed as fixed.
quick note - it might be useful to have the graphics on the home screen show some sort of difference between VPN connection on openvpn and VPN connection on wireguard.
it is not a big deal for us users, but for some people that use multiple profiles it might be great.
